Anyone Ever Try?
pathfinder93x
KA24E
The KA24E was a SOHC 12-valve engine produced from July 1988 through January 1996. It uses SEFI fuel injection, and features forged steel connecting rods, an internally balanced forged steel crankshaft, and a cast aluminum intake manifold.
Specifications
* Bore × Stroke: 89.0 × 96.0 mm
* Max power: 140 hp (105 kW) @ 5600 rpm
* Max torque: 152 ft·lbf (206 Nm) @ 4400 rpm
* Valve Configuration: SOHC, 12 valves
* Compression ratio: 8.6:1 (9.1:1 for early 1989 240SX )
Applications
* 1989–1990 Nissan 240SX
* 1990–1997 Nissan Hardbody Truck
* 1990-1995 Nissan Pathfinder
* 1989–1992 Nissan Axxess
* 1990–1992 Nissan Stanza (USA-spec)
* 1989–1992 Nissan Pintara / Ford Corsair
* 1993-1996 Nissan Terrano 2 Europe
http://en.wikipedia.org/wiki/Nissan_KA_engine#Turbocharged_KA24E.2FDE
You will get 180rwhp with the KA24ET setup. If you go all out you can get somewhere between 400 and 600 horsepower.
http://www.ka-t.org/forums/viewtopic.php?t=5597
Now picture your little truck with 500 hp...
Edited by Tungsten
