Help My Warn Stud Fail
maikan
I was installing my manual hubs today and when I was tightening
the bolts that link hubs with wheels my stud broke at maybe 15 pounds of force !! :thumbsdown:
Luckily I was able to unscrew the stud with a plier.
Two questions for you :
1- Where can I find new stud ? From what I saw Warn don't sell them
2- How can I screw the stud ??
Do I need to screw the studs very tight or this don't matter ?
And after screwing the studs I notice that they are not the same lenght.
And for now I drive with a Warn hub on one side and the stock on the otherside.
If I keep it locked is there a problem?
Until you install the other warn keep the one you have on locked and all should be fine.
When installing mine I double stacked the nuts to tighten the studs. I didn't measure the force just went with feel. I used lock-tite as well.
Maybe some are not the same lenght because they're not tight enough.
HTH!
Have an other question:
When my hub was off I notice a play in the shaft.
It was a good at least a 1/8 to 1/4 from side to side.
The grease was looking very dark too.
Is there something abnormal here.
Thanks
Edited by maikan
There was a kind of retaining ring on the shaft that I took off to get the old hub out.
Do I nedd to put it back on the shaft after the install of warn hubs ?
( Wasn't sure but I did )
When I installed my hubs I broke a stud in the first 10 minutes. I went out and just bought some high grade bolts instead, it made for a much easier install.
is it a stud that broke or an allen head bolt?
It is a stud that failed, one of the stud kit that came with the hubs
If I find high grade replacement stud I will upgrade.
When you say that you bought high grade bolts, you mean that you didn't use
studs, you use bolts instead ?
