Idler Arm
bigred07
so looking at beast paths truck i starting looking at 4x4parts and ruggedrocks at idler arm braces and steering stabalizers and such, i don't really know much about these mechanics in the first place. after seeing beasts braces and the pictures of the calmini ones on ruggedrocks, i went to go look at mine to see if they looked messed up or anything, and the drivers side one is way bigger and different looking, is it supposed to be like that or is this an aftermarket one?
Edited by bigred07
You must be confusing something, because you only have one idler arm (on the outside passenger frame horn). Are you confusing the pitman arm (off of the steering box) or the tie rods in the centerlink?
ok well that makes sense to me now. i was just looking where the idler arm is but on the drivers side, like i said i don't know anything about the stuff down there. thanks.
