shortysmash Posted February 5, 2010 Share Posted February 5, 2010 oh the higway when i give just a little gas i can hear rearend wining. when i let off of the gas it goes away. i checked the fluid level and its fine so im guessing it is the pinion bearing. Has anyone changed theirs. If so how hard is it and what not. and are there any special tools that i need Thanks Link to comment Share on other sites More sharing options...
87pathy Posted February 5, 2010 Share Posted February 5, 2010 to do it properly, your going to have to completely tear it apart. You will need. new bearings (very expensive) seals gear puller and press, Inch pount torque wrench Dial / depth mic Locktite gear marking compound. Possibly new shims for the pinion depth If you have never done it before, have somebody else do it. Link to comment Share on other sites More sharing options...
Precise1 Posted February 5, 2010 Share Posted February 5, 2010 Are you sure it is coming from the rear end?? Sounds like that can be hard to isolate sometimes. When was the last time the gear oil was changed? B Link to comment Share on other sites More sharing options...
shortysmash Posted February 6, 2010 Author Share Posted February 6, 2010 my pathy is an 01 but has 160k i changed the diff fluid about a year 2 years ago. i dunno if that is too long or what but others have told me that if its not leaking at the rear end or at the wheel axle seals then it should be good for a pretty good while. the whine only appears when a load is applied. i know that sounds like that are hard to isolate but i had a friend sit in the very back and he could hear it was coming at the back so i dunno. Link to comment Share on other sites More sharing options...
87pathy Posted February 6, 2010 Share Posted February 6, 2010 could be a poorly set up rear end. what kind of oil did you use? pull your drive shaft, and check for any end or side play. Link to comment Share on other sites More sharing options...
shortysmash Posted February 11, 2010 Author Share Posted February 11, 2010 yeah i dont remember what gear oil i used. its been a good while i just remember it was in a black bottle with green letters, not that that helps. the whine just started to be noticeable about a month ago. so i dunno what to do. i dont really want to take it to someone, if i can do it myself then i want to but if its too much then ill pay to have it done. Link to comment Share on other sites More sharing options...
fleurys Posted February 11, 2010 Share Posted February 11, 2010 I have a 2001 too and I have been having the same noise coming from the same place. It's been going on since I have the path (about 2 years). It has not worsen or lessen and since I change my diff for an arb , all the bearings have been changed so I know it is not that (it was doing the noise before the change for the locker).... Since I was not changing gears, I did not change the pinion nor the pinion bearing.... now I wish I did.... All this to say that I fully think that you're right on with the pinion bearing.... I agree with 87pathy...don't do it yourself if you don't know how to set backlash etc... Link to comment Share on other sites More sharing options...
