Ignition switch housing removal
PATHRIDER
Hey guys any tips on removing a ignition switch barrel housing? Its got a couple of break off bolts on there. I was thinking of using a cut off wheel.Theres a gap in between the top and bottom clamp and it exposes the thead that maybe I can get the cut off wheel in between them to cut the bolts
any suggestions fellas?
it's gonna get replaced, right? sure that should be fine.
if you get one from a junk yard, I would recommend reverse drill bits to save that housing. just backs 'em out. you could go ahead and get them for this, too, to get some extra practice.
Im gonna have to replace them bolts with an allen head and not break-off bolts...Good idea on doing my practice at the jy first .. :beer: thanks bud
