Vg30 Internal Parts
Yeah I have asked about performance parts for the VG30 Motor alot and I have been talking about doing an engine rebuild.
To tease my mind, I wanna know if its possible for me to get a kid of Internals (Pistons, rings, rods, bearings, crank shaft) all in one package as in:
(This is a 3.2L Stroker Kit for the VG30 Motor of the 300zx)
Considering buying a motor from a junkyard might be cheaper to do for my ride I figure it might be a little safer to do an engine build of my own with just replacing parts, considering maintenance is unknown on a junkyard motor and I don't wanna be victim of a timing belt issue!
Let me know your thoughts...
That kits like $13,000 cause its a stroker kit (3.2L) and everything is forged. And its made for the Twin Turbo set up on the 300zx version of the VG30DETT
http://shop.edoperformance.com/jun-auto-nissan-vg30dett-32l-stroker-kit-p-6244.html
Edited by Nytrosfinder
Thats the JUN stroker kit isn't it? don't buy anything from JUN its way overpriced. If you want a stroker you should contact Paeco in Florida. they can cut you a stroker crank from billet(no offset grinding) and shorter pistons (with desired compression ratio) starting at $2k. the options go up from there and there are severlal other companies that make forged pistons for the pathfinder.
