Tire Upgrade!
Day95
So I traded in the stock tires on the ol pathmaker, and got some 31" maxxis big horns.... look amazing, but the sad thing is that i cant turn all the way... it rubs on the inside up front, just means i have to get some offset rims i guess next.
the big wheel and tire package had the turn stops adjusted out more to stop that. So a solution would be to just adjust them out a little.
thanks, i may have to get thats done... but i was also using it as an excuse to buy steelies too.... lol
The old tires were stock,253/75r15... its an xe so it didnt come with the bigger tires, i thought it would be an easy swap too considering. i have the chromie rims that came on her too... as for the sagging i bought aftermarket bars already, i have a 3in sl. its rubbing on the bar on the outside of the torsion bar, not sure what its called tho...
adjust your turn stops, I had 235's too, upgraded to 33x12.50 on 4" offset rims, it will only take a little bit, I just haven't got around to it..
