EGR CODE Question
Donnavon
ok, so I have a CEL and it is the EGR, so I pulled the unit and cleaned it seems to work smooth.
now there are three things in this system how do you test them?
the EGR Valve - check if this holds vacuum?
the BPT valve - ?
The Control solenoid - ?
I wanna check this and the solenoid and bpt are not in the manual or my haynes. need to pass smog NLT halloween
Edited by Donnavon
It goes from the BPT to the egr and it WILL fail on all D21/WD21s eventually. Nearly every single one I have worked on (KA24 and VG30) has had a hole in that hose. It's a schitty rubber tube that has to handle hot exhaust gas. WTF were they thinking?
(edited so I could say schitty)
Edited by KovemaN
