Donnavon Posted October 13, 2009 Share Posted October 13, 2009 (edited) ok, so I have a CEL and it is the EGR, so I pulled the unit and cleaned it seems to work smooth. now there are three things in this system how do you test them? the EGR Valve - check if this holds vacuum? the BPT valve - ? The Control solenoid - ? I wanna check this and the solenoid and bpt are not in the manual or my haynes. need to pass smog NLT halloween Edited October 13, 2009 by Donnavon Link to comment Share on other sites More sharing options...
adamzan Posted October 13, 2009 Share Posted October 13, 2009 Did you check that tiny little hose where the egr is. The one that connects the two metal pipes. Mine had a split, which caused the CEL to come on. Link to comment Share on other sites More sharing options...
Donnavon Posted October 15, 2009 Author Share Posted October 15, 2009 Did you check that tiny little hose where the egr is. The one that connects the two metal pipes. Mine had a split, which caused the CEL to come on. not quite sure I know which hose you are talking about Link to comment Share on other sites More sharing options...
adamzan Posted October 15, 2009 Share Posted October 15, 2009 (edited) not quite sure I know which hose you are talking about This one Edited October 15, 2009 by adamzan Link to comment Share on other sites More sharing options...
KovemaN Posted October 15, 2009 Share Posted October 15, 2009 (edited) It goes from the BPT to the egr and it WILL fail on all D21/WD21s eventually. Nearly every single one I have worked on (KA24 and VG30) has had a hole in that hose. It's a schitty rubber tube that has to handle hot exhaust gas. WTF were they thinking? (edited so I could say schitty) Edited October 15, 2009 by KovemaN Link to comment Share on other sites More sharing options...
Donnavon Posted October 15, 2009 Author Share Posted October 15, 2009 (edited) ok, I will take a look edit: my hose looks good, not super tight but good Edited October 15, 2009 by Donnavon Link to comment Share on other sites More sharing options...
