Ramon Posted October 8, 2009 Share Posted October 8, 2009 I have been in trouble with my corner lights recently I turn on the switch and the dash and corner lights not turn on then I turn on the headlights and they work but the dash and corner still no . After a while of driving he lights come on suddenly (corner and dash) this happen to me rarely most of the times they come on as good as ever what can be causing this the switch is dirty or may be a relay is failing? have this happened to you too? thank you in advance for all your help Link to comment Share on other sites More sharing options...
MikeV Posted October 8, 2009 Share Posted October 8, 2009 Possibly a bad common ground? doubt it is a relay, sounds more like a loose wire. If I get time I'll look at the wiring diagram and get back to you. Link to comment Share on other sites More sharing options...
edicer2 Posted October 8, 2009 Share Posted October 8, 2009 i bet its a bad contact in the switch. Link to comment Share on other sites More sharing options...
Ramon Posted October 10, 2009 Author Share Posted October 10, 2009 Possibly a bad common ground?doubt it is a relay, sounds more like a loose wire. If I get time I'll look at the wiring diagram and get back to you. I have to admit is is extrange i bet its a bad contact in the switch. I will open the combination switch tomorrow and clean it may be this will fix the problem Link to comment Share on other sites More sharing options...
DavefromOZ Posted October 10, 2009 Share Posted October 10, 2009 i bet its a bad contact in the switch. x2 Link to comment Share on other sites More sharing options...
Ramon Posted October 12, 2009 Author Share Posted October 12, 2009 Thank you guys I clean the switch with sand paper it was dark as night bu is working good now Link to comment Share on other sites More sharing options...
