daopi Posted September 27, 2009 Share Posted September 27, 2009 I just noticed today that my Pathfinder is tilted / slanted when stays on level ground, looking at the back. I measured and looks like right side is 1 inch higher than left. What can be other than the springs? I have installed BDS springs front and back ( 2 inches lift), and Monroe Sensatrac shocks/struts. Thank you! Link to comment Share on other sites More sharing options...
shift220 Posted September 27, 2009 Share Posted September 27, 2009 Are you sure the springs are seated correctly? I suppose it could be a bad shock or something in the suspension binding as well Link to comment Share on other sites More sharing options...
Formerly_94PathyMan Posted September 27, 2009 Share Posted September 27, 2009 X2, also check to see if your sway bar may be a factor, had a car once that I had to change over the linkage and it then sat level. Just a thought! Link to comment Share on other sites More sharing options...
OfftourRoadie96 Posted September 27, 2009 Share Posted September 27, 2009 I'm the original owner of a 96, and when I brought mine in for an oil change at the dealer the did alot of service work as part of a service bulletin. I think part of it was leveling out the rear. This was all free of charge of course, at least back in 96! Link to comment Share on other sites More sharing options...
180sx Posted September 27, 2009 Share Posted September 27, 2009 Mine sat like that for a while because my sway bar endlink was bad. also anothere time because the strut bearing (spherical bearing) has broke and disapeared all together. By the way, whats BDS? Jose Link to comment Share on other sites More sharing options...
daopi Posted September 27, 2009 Author Share Posted September 27, 2009 By the way, whats BDS? BDS suspension. They stop making the lift kit for Pathfinder 2 years ago or so. Here is the link: http://www.bds-suspension.com/ Link to comment Share on other sites More sharing options...
daopi Posted September 27, 2009 Author Share Posted September 27, 2009 I'm the original owner of a 96, and when I brought mine in for an oil change at the dealer the did alot of service work as part of a service bulletin. I think part of it was leveling out the rear. This was all free of charge of course, at least back in 96! Do you know what work for leveling? Link to comment Share on other sites More sharing options...
sammyb33 Posted September 27, 2009 Share Posted September 27, 2009 do you have a full tank of gas? Link to comment Share on other sites More sharing options...
daopi Posted September 28, 2009 Author Share Posted September 28, 2009 do you have a full tank of gas? Good question! The tank is half. I use the car for work, and normally I carry some tools or something. Now is quite empty and maybe that's why I noticed only now. I guess is possible to look tilted now because of the tank. When the car is normal loaded I don't see much of the tilt. Anyway, I will try to have checked the sway bar also. Link to comment Share on other sites More sharing options...
