One final lift question
pathydaddy
So after reading many many posts on lifting my pathy what i have come up with is i can buy a kit for a few hundred bucks or i can piece together a setup...correct?
so it is to my understanding if i get new UCS (like rough countrys) jet me a set for V8 JGC coils and some new shocks ill have myself a a2.5-3in lift correct or am i missing somehting?
i k now its been covered many times but so many posts say so many different things lol
that is true, but the JGC lift is a crap shoot, you MAY get 3" but you MAY get 2" or less, it really depends.....
But in theory, that setup will get you 2.5"-3" of SL
so no random brackets or anyhting? nothin else needs to be altered( othere than alignment) just bolt everyhitng in and bam there it is?
UCA's, crank the T-bars until .5" from the bump stop (seems about the standard), install the taller/hisher load springs and replace the erar shocks. BAM!! There you have it.. :D
You may want to invest in (or make) a pan hard rod mount drop bracket (lateral bar on the rear axle). They can be had for about $60 IIRC.
  • 7 years later...
IIRC?
Also, I've been doing a ton of research for lifting an '02 but this is the first time I've heard of a JGC lift. I thought there was basically only OME & AC (though I thought I ran across a mention of something like BDS). By sheer coincidence, I just so happen to have a 2006 WK JGC that I'm going out to harvest in a couple weeks. I thought it's lift was a 2" TerraFlex. Can you point me in the direction of the JGC-Pathfinder crossover info.
