Replacement oxygen sensor
92Pathy808
My 92 5spd pathfinder has 163k+ on the clock and with my current misfire, might be a good time to change the original oxygen sensor. Some of the sensors I found were in upwards of $150 but found this one: http://shop.oreillyauto.com/ProductDetail....291&PTSet=A for $35. My question is how would I hook it up since the original sensor has two wires coming from it that goes to a wiring harness and this one only has one? Do I need a heated one or non-heated? Mine is located on the down pipe. Thanks.
I am pretty sure you need the 2 wire heated unit. Bosch sells one for around $60 that you splice in to the existing connector; that is about as cheap as it gets. I'd stay away from the $25 no name, vague description units. Saving $ is fine, but your truck needs decent info to run right. Just my .02... :shrug:
