mkedwards Posted August 30, 2009 Share Posted August 30, 2009 im trying to change out all 3 belts but i cant figure out how to get the power steering belt off. its driving me nuts! i feel like it this should be really easy, ive tried using search and found a couple threads but none really helped me out. ive loosened the adjusting bolt behind the pulley and what i believe to be the mounting bolt behind the pulley through the hole in the front (if that makes sense) dont know what to do from here Link to comment Share on other sites More sharing options...
94extreme Posted August 30, 2009 Share Posted August 30, 2009 you also have to loosen each one of the components (ps, alt, etc) Link to comment Share on other sites More sharing options...
adamzan Posted August 30, 2009 Share Posted August 30, 2009 There should be a bolt on the side that is really long, that is the adjusting bolt. It was easier for me to go in through the fender well with the tire turned. Used a long extension too. Link to comment Share on other sites More sharing options...
mkedwards Posted August 30, 2009 Author Share Posted August 30, 2009 yep thanks, got it all done today. didnt take long once i figured it all out. Link to comment Share on other sites More sharing options...
