Mookie Posted September 27, 2009 Share Posted September 27, 2009 Turns out the fuse wire had broke in half inside the insulation, spliced it and it started righ up. Going to order a new link on Monday, but for now I can at least move the truck again. Good to hear! Link to comment Share on other sites More sharing options...
Terrano1992 Posted September 27, 2009 Share Posted September 27, 2009 Turns out the fuse wire had broke in half inside the insulation Broken only, without any traces of melting? If ends of wire conductor are melt, you probably have intermittent short circuit somewhere across a harness... Link to comment Share on other sites More sharing options...
GrimGreg Posted September 27, 2009 Author Share Posted September 27, 2009 Broken only, without any traces of melting?If ends of wire conductor are melt, you probably have intermittent short circuit somewhere across a harness... Yep, no sign of melting, the insulation was still perfect, no bubbles, texture or coloration differences. The wire looked like it had been cut inside the insulation. The connector ends are just fine, the part that looks melted or worn down is the connector end on the battery terminal, and it is on the outside away from any of the electrical connections, where the connector would lock in place. Link to comment Share on other sites More sharing options...
GrimGreg Posted October 3, 2009 Author Share Posted October 3, 2009 I got the new link in and replaced the battery (it wouldn't hold a charge anymore) and all is working well! Link to comment Share on other sites More sharing options...
