trenton163 Posted July 21, 2009 Share Posted July 21, 2009 i know a lot of people have this, i was wondering if anyone knows a good fix for this, beside tighting the TBars? mine sitts real low and i hate it. i know even when they were new the front end sat a little lower than the back, but mine is real low? Link to comment Share on other sites More sharing options...
Kingman Posted July 21, 2009 Share Posted July 21, 2009 The torsion bars get weak and sag over time, cranking them or replacing them is your only solution. Some sag worse than others... Link to comment Share on other sites More sharing options...
RedPath88 Posted July 22, 2009 Share Posted July 22, 2009 If you crank them up and it is still to low or it sags down a bit to far after you adjust them, then reindex the bars before you replace them. Don't look at it as "tightening" them, because the spring rate of the bars does not change. But it does change if you go with stiffer aftermarket bars Instructions on adjusting and reindexing can be found in the Garage Link to comment Share on other sites More sharing options...
ekupathy87 Posted July 22, 2009 Share Posted July 22, 2009 might as well get used to it, even with a lift mine does it... i'd just try to crank them enough to make it better than it is, but they normally always have a raked look Link to comment Share on other sites More sharing options...
