nose down stance
i know a lot of people have this, i was wondering if anyone knows a good fix for this, beside tighting the TBars? mine sitts real low and i hate it. i know even when they were new the front end sat a little lower than the back, but mine is real low?
If you crank them up and it is still to low or it sags down a bit to far after you adjust them, then reindex the bars before you replace them.
Don't look at it as "tightening" them, because the spring rate of the bars does not change. But it does change if you go with stiffer aftermarket bars ;)
Instructions on adjusting and reindexing can be found in the Garage :aok:
