Jared Posted July 5, 2009 Share Posted July 5, 2009 Doing a rebuild on a 2005 PathFinder and I am in need of a valve body breakdown diagram. A heads up on your Pathfinder (Which I'm sure this topic has been discussed before) I would recommend putting external transmission coolers on your ride. The '05 we are working on is due to the walls collapsed in the radiator allowing the transmission fluid/anti-freeze to mix. I would put an external cooler on and do away with the cooler lines going through the rad. Thanks in advance Jared TTS Link to comment Share on other sites More sharing options...
GrimGreg Posted July 8, 2009 Share Posted July 8, 2009 Wow, Nissan just can't get the tranny coolers right, STILL! What is the tranny on the 05? Link to comment Share on other sites More sharing options...
Jared Posted July 9, 2009 Author Share Posted July 9, 2009 Rebuild is complete. The transmission works smoothly and the customer is happy. Thankfully I was able to source the correct information on this transmission, and believe me it wasn't easy! So I am posting these photos in hopes that the next tech searching for information will have atleast something. We mainly needed a diagram showing where the check-balls went which I will upload later. -Jared Trouts Transmission Svc FYI - We searched for used transmissions and we only found two the prices where $3,200 and $4,100. We did the rebuild and flushed engine for a little over $2,000 with new converter too. We installed two #18,000GVW coolers. Hope this helps! Link to comment Share on other sites More sharing options...
