HELP electrical
N2mesnob
Ok heres what it looks like:
My first attempt: connect to ignition wires :puterpunch:
What not to do: connect to ignition wires :suicide:
Here's what i came up with (w/help)
My second attempt.
So i tested both wires before i taped them up.
I get 11.4 on the blue/black (accessory) wire and the black wire (ground) beeps so i should be all good.
Still not working i think all i need is a new LED, unfortunately I have no idea where or which one to get.
Does anyone know LED size, type part#, and/or where i can find it?
So your trying to add a glow ring arround the key? Will this be lit @ all times or Just @ night or just while the dome light is on?
as for the LED, remove it so you know the physical size and go to radio shack. Buy a new led pref in the 4-6.5v range or a 12v if you want it brighter (if its small enough) Google "LED resistor calculator" input the information about the LED you have and 13v as your input voltage. then go buy the resistor it tells you you need and solder it on the + side of the LED...
