zerenix Posted May 8, 2009 Share Posted May 8, 2009 I'm sure I'm just missing something easy here.. but how do you remove the cam seals? Link to comment Share on other sites More sharing options...
Indigent Posted May 9, 2009 Share Posted May 9, 2009 Jam a screwdriver or scribe in there and pry it out. It will probably feel wrong, but it will work. Link to comment Share on other sites More sharing options...
zerenix Posted May 9, 2009 Author Share Posted May 9, 2009 Yeah thats what I eventually did, thanks Link to comment Share on other sites More sharing options...
TerranoNZ Posted May 9, 2009 Share Posted May 9, 2009 The way I do it is to drill a small hole in it, or 2. Then screw in a wood screw and pull on them with a pair of pliers Link to comment Share on other sites More sharing options...
MY1PATH Posted May 9, 2009 Share Posted May 9, 2009 The way I do it is to drill a small hole in it, or 2. Then screw in a wood screw and pull on them with a pair of pliers Yes, then there is less risk of maring the shaft. Link to comment Share on other sites More sharing options...
