antpathy Posted April 13, 2009 Share Posted April 13, 2009 Cheers, I just bought a 95' Pathy SE, thanks to all the info from you guys I've pretty much got all the lights working by changing out the headlight switch assembly. Now I've got no brake lights, my question is does this cicuit get it's power from the turn/headlight switch also? All the lights work, turn signals, dash, hazards, daytime all work perfect, but no brake lights. I tested the sockets and I have power to the tail lights but no brakelights ( when pedal is pushed ). I was thinking it's the actual switch at the pedal, is this another common weak spot? I just thoght I'd ask before I start taking stuff apart because I can't really get under there without removing it to test it. Oh yeah, I've checked the fuse panel and everything there seems to be good. Please Help. Link to comment Share on other sites More sharing options...
88pathoffroad Posted April 14, 2009 Share Posted April 14, 2009 It could be the switch at the pedal, yes. Check it with a flashlight (torch) maybe? Another cause could be that both bulb filaments are simply burned out, or towing wiring could be wonky, or perhaps corrosion exists in the bulb sockets. Link to comment Share on other sites More sharing options...
antpathy Posted April 14, 2009 Author Share Posted April 14, 2009 I changed out the bulbs for new ones, and checked the sockets for corrosion , I'm pretty sure it's the switch at the pedal. I'll have to pull it out to check it I guess. Link to comment Share on other sites More sharing options...
alexrex20 Posted April 14, 2009 Share Posted April 14, 2009 backtrace it with your multimeter Link to comment Share on other sites More sharing options...
antpathy Posted April 16, 2009 Author Share Posted April 16, 2009 After trying to get to the switch at the pedal for about 20 minutes I realized that the plug going to the switch wasn't plugged in !!!!!!!!!!!! Yesterday I couldn't spell backyard mechanic, now I are one Link to comment Share on other sites More sharing options...
Precise1 Posted April 18, 2009 Share Posted April 18, 2009 LOL, the easy/free fixes are always the best... B Link to comment Share on other sites More sharing options...
