fleurys Posted April 4, 2009 Share Posted April 4, 2009 (edited) OK... Bought everything to pre-mount the kyb struts and the ac coils for my incoming lift. I thought by doing so I would save time...now I'm losing time ! First , Here's what I bought: 1) KYB Strut (goos part number for my year...just don't remember it now) 2) KYB Bumpstop/boot 2) Nissan upper seat 3) Nissan strut bearing 4) Nissan plate (with the 3 threaded studs) 5) Nissan strut tower mount 6) Nissan spacer (Thin paper isolator) Now I'm simply doing a test fit without the spring just to accomodate myself with the order the things goes in. Well, when all part are assembled, the strut shaft is actually BELOW a 1/4 inch or so from the strut tower mount !!! here's the pictures : I know, that it was talked about once on the forum : http://npora.ipbhost.com//index.php?showto...strut++bumpstop The solution is said to cram them on....now my english is not THAT good...what does cram means ?? Any ideas ?? I guess I could always grind some of the white bumpstop... Taking the old bumpstop is not an option since I do not want to have to wait to dismantle the old one to assemble the new setup... Tks.. Edited April 5, 2009 by fleurys Link to comment Share on other sites More sharing options...
02silverpathy Posted April 4, 2009 Share Posted April 4, 2009 Dude, that sucks. That is what it should look like with Lift springs on there not without springs at all. That bump is keeping you all right. I would save those for the back of your rig. If you stuffed the fronts that high your tires would bang up your fenders before that bump could help...at least I should think. Super super smart buying those Nissan parts instead of KYB mounts and bearing! Good work mate! Link to comment Share on other sites More sharing options...
Jarsiff Posted April 4, 2009 Share Posted April 4, 2009 that looks odd, so he should keep the bump stop out? or should that all be assembled at a shop where they could compress it? Link to comment Share on other sites More sharing options...
88pathoffroad Posted April 4, 2009 Share Posted April 4, 2009 Perhaps you could use a cheap spring compressor to compress the springs a little before install. It should bolt together OK that way. Link to comment Share on other sites More sharing options...
fleurys Posted April 5, 2009 Author Share Posted April 5, 2009 **FIXED*** I wrote to kyb...surprisignly, they have tech support even on saturday....well, the guy tells me that it needs to go down lower on the shaft... Well all along, I did not wanted to force anything, so I never thought of that.. And the hole in the bumpstop is far smaller then the strut shaft, but it still goes... Here are the pictures for anyone following with the same issue... It was my first attempt at strut "building"... So I learned... Here is the strut, if you start from the top there is 3 shaft diameter... We'll call them d1,d2,d3 1 being the threaded one. So when you put the bumstop, it basically stop sitting on d2, because the hole is not even as big as d2...so the problem was coming from there... I thought this was it's resting place. You actually have to force it down to the main shaft (d3) Once i put everything else on top, I got this : One thing to know is that you also have to force the bumstop into the upper spring seat. I good deal of convincing must be applied :-) This is what it looks like from under have a look at the bumstop hole and compare it to the main shaft (d3) diameter...now you know why i never thought this was going there... Link to comment Share on other sites More sharing options...
FUELER Posted April 6, 2009 Share Posted April 6, 2009 thats what she said Link to comment Share on other sites More sharing options...
88pathoffroad Posted April 6, 2009 Share Posted April 6, 2009 Good job on getting it figured out! Link to comment Share on other sites More sharing options...
m0nkeyprince Posted February 26, 2011 Share Posted February 26, 2011 hey thanks alot!, i was just about to cut my bump stop in half haha this should be pinned cuz i bet alot of us are gonna spring for kyb boots Link to comment Share on other sites More sharing options...
