ac92pathfinder Posted March 27, 2009 Share Posted March 27, 2009 (edited) came on this morning while i was warming up the car this morning. both just came on for a quick second then off. probably nothing drove fine for a few hours this morning. kinda messed with the idle at the same time just for a quick second. anyone ever had this happen? probably nothing. thanks Edited March 27, 2009 by ac92pathfinder Link to comment Share on other sites More sharing options...
GrimGreg Posted March 27, 2009 Share Posted March 27, 2009 That usually indicates an issue with the alternator, either the belt slipped (causing the lights to come on and go back out) or it is trying to die. Mine will flash on for a moment if I hit a big puddle and cause the belt to slip. I would say check your belt and belt tension, and keep an eye on the lights, if they come on and stay on then the alt has died. Link to comment Share on other sites More sharing options...
