front bumper issue
MudFinder95
Ok so i bought a pair of 3x5" 55watt halogen fog lights with the yellow lenses. and i want to mount them either on top of the front bumper on either side with has been done before a lot. OR cut out the plastic black bar beside the signal light and have them in there (they prob wont fit tho) so for the top how would i put on the nut to the underside of the bumper when mounting the light through the hole i drill in the top??? i dont want to take off the bumper because the bolts will all probably break. do you think i can take out the signal light bezel and reach my hand in there to do it? or how else would i do this....
Thanks!
also i was bored so heres some random pics of the rig
Just remove it. I've had my front bumper off 2 95's without any issue or bolt breakage. Never been an issue. There's only 2 bolts per side, accessible through the wheel well. It's a hell of a lot easier than trying to do it with the bumper on.
or, if you are mounting them on the top part of the bumper, looks like oyiu have more than enough gap int he buper to fit fingers with nuts n washers..... but yeah, i'd just take the bumper off
Just remove it. I've had my front bumper off ... Never been an issue. There's only 2 bolts per side, accessible through the wheel well. It's a hell of a lot easier than trying to do it with the bumper on.
x3
they are in the frame, behind the wheel kind of
i looked under the bumper and saw the black bar/mount thing going from the bumper to some where on the frame maybe. on the inside of the wheel well i have these rubber flaps. are the bolts behind the flaps by the frame?
the rubber flaps have plastic things that you can pop off to remove a portion of the flap, but the flap is easy to get tears in especially at this age. Mine are completely gone from being torn, taken on/off, etc.
