ac92pathfinder Posted March 22, 2009 Share Posted March 22, 2009 i have a 92 pathfinder xe 3.0 someone by passed the plug thaty goes into the temp switch to the battery instead i plugged it into the switch but doesnt work along with the gas gauge. if i leave it on the battery i get back and fourth readings like one time it said i was over heating and it would sit on cold too. what can i do to fix this? thanks Link to comment Share on other sites More sharing options...
M in KC Posted March 22, 2009 Share Posted March 22, 2009 See if your voltage regulator behind your instrument cluster hasn't failed. Pretty common issue on our gen 'finders. I think there is a how-to in WD-21 section. It's about a 30 minute project IIRC when I did mine a couple of years back. Link to comment Share on other sites More sharing options...
M in KC Posted March 22, 2009 Share Posted March 22, 2009 Sorry try here. http://npora.ipbhost.com//index.php?showto...ltage+regulator Link to comment Share on other sites More sharing options...
ac92pathfinder Posted March 22, 2009 Author Share Posted March 22, 2009 i didnt see it in there. also i have brake fluid leaking between the master and booster is this a master cyl problem? if so is it rebuildable? thanks Link to comment Share on other sites More sharing options...
ac92pathfinder Posted March 22, 2009 Author Share Posted March 22, 2009 i take that back. Problems with your fuel and temp gauges are common with the 95 and older trucks. On the back of your cluster is a small box with some wires coming out of it going to different points on the cluster. This is a voltage regulator for the gauges and it is known to fail. I got a new one at my local dealer for about $25 and it took about a total of 2 min to replace. (from MrReverse) is this located behind the instrument cluster do i have to remove that? also my heater controls dont work the hot and cold does along with the fan but i can get the controls like the defrost and sround that area to work also they dont light up. just my speedometer area. i checked for blow fuses i didnt see any. Link to comment Share on other sites More sharing options...
M in KC Posted March 23, 2009 Share Posted March 23, 2009 Yes you have to remove the instrument cluster to access the voltage regulator. A few screws and putty knife to pry the top edge of the cluster out from under the dash. It shouldn't be a big deal. I can't help you on the HVAC controls but I presuming they are vaccum driven. While you are there keep disassembling the dash panels to access the HVAC controls as well. Maybe something(s) have become disconnected. As faith would have it I have an intermittenat HVAC illumination issue as well. So far I have just lived with it as my selectors still work. Link to comment Share on other sites More sharing options...
ac92pathfinder Posted March 23, 2009 Author Share Posted March 23, 2009 what does the voltage regulator look like so i dont pull the wrong one by accident Link to comment Share on other sites More sharing options...
alexrex20 Posted March 23, 2009 Share Posted March 23, 2009 temperature* Link to comment Share on other sites More sharing options...
M in KC Posted March 24, 2009 Share Posted March 24, 2009 http://www.nissanpathfinders.com/Solution2.pdf Can't make it any simplier than this. Link to comment Share on other sites More sharing options...
