tire size on original rim!
tino
my 89 two door came with a 15- 6 rim i have now 235-75 -15 what is the bigest size tire can i use without adding a lift kit/\? i also notice the front is sagging a bit?
Some wd's came from the factory with 31"s but your proably gonna have to put your sagged front end back up(search for how to on adjusting the torsion bars-not hard). Don't think your goeing to get bigger without some modifying especially with the old 3+3=33"s rule(3" sus+ 3" body=33"s) so I dobt 32"s are goeing to fit without doeing something.
31's came stock on many wd's but those usually also came on 15x7 rims.
with a 15x6 rim I would reccomend 30x9.5 max tire size.(makes balancing easier)
if you get a 15x8 rim you can run 31's fine and lager later on if you lift it.
you can tighten your torsion bars with a pair of 19mm wrenches in about 20 min. search the how-to's for tips.
thanks a lot guys , i will look in to it.
I know I have 31X11.5X15's on my Legos. It all depends on what size of rim you have....Some of the steel rims are smaller, so 31X10.5's might be pushing it. Just call and ask a tire shop. I called and talked to someone @ 4Wheel Parts.
