dagwoodzz Posted August 8, 2004 Share Posted August 8, 2004 That was a lot of fun. installed JGC springs. Do have a lessons learned to share. I was limited with a short jack. Had to drive up a ramp, block frame then lift axle & remove tire to get ramp out of way. (one side at a time.) wanted to be smart but I wasn't. When doing the 2nd spring I put the spring coil compressor on before I jacked up the Pathy. It popped out with very little encouragement. Could have saved a lot of time had that been done with the first spring. Now ready to lift the front by cranking torsion bars. A lot of recommendations posted for adding ball joint spacers to reduce wear & tear. Is there a detailed write-up for adding spacers. the most front-end experience I have is changing flats & brake pads. Are you better off just paying a professional? I have a lot of time but not much dough! Link to comment Share on other sites More sharing options...
88pathoffroad Posted August 8, 2004 Share Posted August 8, 2004 There's nothing to adding the spacers, simply unbolt the upper balljoint, lift up the upper control arm a bit, slip in the spacer, then put new bolts in the balljoint. Easy as pie. Link to comment Share on other sites More sharing options...
dagwoodzz Posted August 8, 2004 Author Share Posted August 8, 2004 Thanks '88 I'm pretty sure you authored the rear suspension lift instructions that were followed. You did a great job. Not one surprise. :bow: Do have one question, looking at Pathy closely, it looks like the passenger side is about an inch higher in the back than the driver side. Could that be one of the used JGC spring is more residual or saw less load? The rear shocks have " made in japan" on them. Probably original '87s. Would replacing them help? Link to comment Share on other sites More sharing options...
dagwoodzz Posted August 10, 2004 Author Share Posted August 10, 2004 Woops, to fast to judge. Looked at it with a friend. He convinced me the tail pipe was giving me an optical illusion. With the tail pipe in the way, you can see more tire tread on one side that the other. I'm pretty sure i'm level now. Link to comment Share on other sites More sharing options...
94extreme Posted August 10, 2004 Share Posted August 10, 2004 i'd suggest a tape measure... Link to comment Share on other sites More sharing options...
