Speedy VG30E Replacemtn / Rebuild tricks
SteeevO
start now
pickup parts when the stores open
should not be an issue to make your schedule
remove the fan cowl, take the fan off the water pump, start removing things for clearance (belts etc) then the covers.
Ignore the t-stat etc unless you find you have time before putting it back together.
if you are lucky and can get the crank pulley off without a puller, you shouldn't have to pull the radiator. It may take a little longer to systematically tap it off but takes less time in the long run
