Suspension noise on passenger side?
nmpath
The passenger side of my path makes a clunk when I go over speed bumps. I found out I had a worn out strut mount and I replaced it assuming this would fix my problem. It is still making the noise after the install and alignment. Any ideas on this?
Could be a worn inner tie rod end, ball joint, swaybar bushing or swaybar endlink.
