mikeinIdaho Posted December 18, 2008 Share Posted December 18, 2008 The Defroster vents are the only ones that are operating on my 93SE Pathy. I am thankful that my windows are at least clear! But my toes are getting cold. Has anyone else had this happen? No matter which vent button is pushed it still only goes through the defrost vent. thanks Link to comment Share on other sites More sharing options...
Dowser Posted December 18, 2008 Share Posted December 18, 2008 (edited) Ya I have. Have you got the Manual switches or the Push Button switches? behind your Center console with the Radio, is a set of cables that go to the mechanism that changes the different heat areas. They are clamped so that they cannot move around and I found my clamp had broke loose. Most likely from the Cold -40C and me switching without waiting for it to warm up. If that's not the issue there then its on the other end which Isn't such a peach to get at. No matter which vent button is pushed it still only goes through the defrost vent. Didn't register this in me old Brain before I posted. I had the manual version so not sure how the Bush button ones operate but I'm sure its VERY similar. Edited December 18, 2008 by Dowser Link to comment Share on other sites More sharing options...
GrimGreg Posted December 18, 2008 Share Posted December 18, 2008 The push button type have a servo that runs the damper IIRC, maybe a blown fuse or bad servo? Link to comment Share on other sites More sharing options...
