Timing belt replacement for a 1995 SE-V6
zack1978
Hi everyone,
I checked in the "garage" how to section, and the timing belt replacenment is not for the WD21 Path's. Is there a specific "how to" for up t0 1995 Pathfinders? If none exists, how much different is the job on the newer vs older Path?
Thanks,
Zack
It's easier. There's less in the way. Once you get into the timing covers, the job is exactly the same. Actually, most of the job is exactly the same, except that the accessories are in slightly different places. That "How-To" is quite thorough, and will do the job just fine for you.
