krypto Posted September 3, 2008 Share Posted September 3, 2008 Okay so when i got my truck the only thing on my cluster guage that works is the rpm and clock. I have changed the fuses and even pulled the cluster guage off to look at the wiring but there isnt as much wiring as i expected. And the speedometer is just a press fit i believe which confused me alil bit. Has anyone had this problem if so how did you fix it? Just a reminder its an 1988 Link to comment Share on other sites More sharing options...
jj big shoe Posted September 3, 2008 Share Posted September 3, 2008 Check the link below. If that doesn't help, try the search function at the top of the forum. A lot of problems have been discussed before so usually you'll get the answer you're looking for sooner by searching rather than just posting a question (plus you won't get the generic "use the search button" reply). Link Link to comment Share on other sites More sharing options...
GrimGreg Posted September 4, 2008 Share Posted September 4, 2008 My speedo needle was bent when I bought my 88, PO had cut it, I actually put some new plastic on mine. Link to comment Share on other sites More sharing options...
