cluster guage?
krypto
Okay so when i got my truck the only thing on my cluster guage that works is the rpm and clock. I have changed the fuses and even pulled the cluster guage off to look at the wiring but there isnt as much wiring as i expected. And the speedometer is just a press fit i believe which confused me alil bit. Has anyone had this problem if so how did you fix it? Just a reminder its an 1988
Check the link below. If that doesn't help, try the search function at the top of the forum. A lot of problems have been discussed before so usually you'll get the answer you're looking for sooner by searching rather than just posting a question (plus you won't get the generic "use the search button" reply). :)
Link
