87 Pathfinder fuel line replacement?
87PathfinderXE
Okay so I was out playin in the mud last night and when I pulled back into the garage I noticed a pool of gas by my passenger rear tire after further examination I saw I had a fuel line leak, theres a small bracket that holds the lines to the frame I was wondering if theres any way to replace that section and not have to do it all
If it is the hard line then you can splice it, but if it is bad back there it is probably bad the whole length of the line. To splice it you just need a tubing cutter, a section of new line, a coupling and a flare tool.
