Jillebean Posted July 15, 2004 Share Posted July 15, 2004 My '95 Pathy has been making some awful noises lately that I'm pretty sure are due to the throwout bearing. Is it easier to drop the tranny or do I need to pull the engine to fix it? Link to comment Share on other sites More sharing options...
87pathy Posted July 15, 2004 Share Posted July 15, 2004 is it making a wineing sound when the clutch is depressed? if so, mine started doing this several years ago and i still havn't changed it Link to comment Share on other sites More sharing options...
Mr. Pickles Posted July 15, 2004 Share Posted July 15, 2004 Mine did the noise routine for a year until I had the clutch replaced a few weeks ago. Sure enough the throwout bearing was shot. Link to comment Share on other sites More sharing options...
88pathoffroad Posted July 16, 2004 Share Posted July 16, 2004 You just need to take out the transmission/t-case(if it's 4WD) to change out the clutch and throwout bearing. Link to comment Share on other sites More sharing options...
MatterHorn Posted July 16, 2004 Share Posted July 16, 2004 mine was making that noise too ... so I replaced the throwout bearing ... noise was still there ... turns out it was the pressure plate ... Link to comment Share on other sites More sharing options...
Jillebean Posted July 17, 2004 Author Share Posted July 17, 2004 I guess i should restate what i am asking. I know my throw-out bearing is bad because of the whining it makes when i press in the clutch. I need to know if it is easier to yank the motor or drop the tranny to change it. I found a new clutch, throw-out bearing, and pressure plate for $180 local. Unfortunately it is a 2wd. My boyfriend said he would help me change it, but i figured someone here might have some insight for me to make this easier on me. Thanks in advance. Link to comment Share on other sites More sharing options...
88pathoffroad Posted July 17, 2004 Share Posted July 17, 2004 The 2WD is easier to work on than the 4WD. Like I already said, just drop the transmission, change it out and put it back together. No need to remove the engine. I dunno who told you that was even an option... Link to comment Share on other sites More sharing options...
Jillebean Posted July 18, 2004 Author Share Posted July 18, 2004 Thanks for the info. My BF is always busy working on other cars, so i was looking for some info to do this myself. Link to comment Share on other sites More sharing options...
