ronin152 Posted August 3, 2008 Share Posted August 3, 2008 Saw these on summit http://store.summitracing.com/partdetail.a...r=1#Application they say they fit 1996 - 2002 but I wasn't aware that the strut design changed in 03 and 04? Will these bolts work on an 03? I don't feel like spending 30 dollars from AC. Link to comment Share on other sites More sharing options...
nissandoms47 Posted August 3, 2008 Share Posted August 3, 2008 Those look exactly like the ones AC sells. The strut designs are the same. I'd go ahead and buy the summit ones. Saw these on summit http://store.summitracing.com/partdetail.a...r=1#Application they say they fit 1996 - 2002 but I wasn't aware that the strut design changed in 03 and 04? Will these bolts work on an 03? I don't feel like spending 30 dollars from AC. Link to comment Share on other sites More sharing options...
ronin152 Posted August 4, 2008 Author Share Posted August 4, 2008 The bolts come in ± 2° or ± 1° which should I get? And do I only need 2 per wheel or only 1 per wheel. Link to comment Share on other sites More sharing options...
02silverpathy Posted August 4, 2008 Share Posted August 4, 2008 I per wheel or 1 set of two bolts should be fine...you'll just drill out both holes a little on each side and install your camber bolts in the top strut opening. You'll drill the top hole so that the camber bolt can be a little more workable and the bottom hole so that you can tilt the wheel a little further out. Get the 2 degree ones for sure! Link to comment Share on other sites More sharing options...
