Dreadeyed Posted July 13, 2004 Share Posted July 13, 2004 I'd like to know exactly what's needed to be done or replaced on my 97 Pathy if I intend to put a 20" or 22" tires on it. I'm willing to add them on. Is there any down grade when adding bigger tires?. I'm assuming, maybe the performance could be different or might burn more fuel. Link to comment Share on other sites More sharing options...
Mr. Pickles Posted July 13, 2004 Share Posted July 13, 2004 This sorta touches on the subject. With bigger tires, the effect is like changing the gearing. You won't feel as much pull off the line, and you'll cruise around at lower RPM's at the same speed. On flat ground, that isn't too bad, but once you hit a hill you'll really start to notice it, and you'll probably have more shifting there to keep up your speed. You'll probably lose a few mpg also. Link to comment Share on other sites More sharing options...
88pathoffroad Posted July 15, 2004 Share Posted July 15, 2004 Um, 20" tires would be very small indeed. I hope you're talking about wheels instead. Link to comment Share on other sites More sharing options...
Mr. Pickles Posted July 16, 2004 Share Posted July 16, 2004 Um, 20" tires would be very small indeed. I hope you're talking about wheels instead. Details, details. Would you rather they went all ghetto and asked about fitting "Dubs" or something? Link to comment Share on other sites More sharing options...
