packie88 Posted July 10, 2008 Share Posted July 10, 2008 alrighty i have 3 h233b sitting at home. the first one is out of an 87 it is drum brake 9 botls to get the 3rd member out non lsd the second one is out of my 94 it is drum brake 10 bolts to get the 3rd member out non lsd the third one not sure on year. and it has 9 bolts to get the 3rd member out. and it has an lsd. also the rear cover piece looks longer but my question is that did nissna make rear axles that had both 9 and 10 bolts in the h223 b. or are the other ones the h233a or what. and are the insides the same is my next question. or just any info on axle identification would be nice Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted July 10, 2008 Share Posted July 10, 2008 I'm like 90% the innards are all the same. I cant remember what exactly AC/4x4parts did with the 5.13 ring gear to make it work with ALL h233bs. I recall seeing a post about Phil or Lee using the 9 bolt in lieu of the 10 bolt h223b. and had no problem.. Link to comment Share on other sites More sharing options...
McClurgM Posted July 20, 2008 Share Posted July 20, 2008 Nissan did mabe both the H233A and B with different bolt numbers The 10 bolt is the B the 9 bolt is the A. The H233A as actual bolts. THe H233B housing has studs. Internals are slightly different. The pinion is different but the rest is the same. I have a H233A 3rd with 4.88s in a H233B housing it works just fine. Link to comment Share on other sites More sharing options...
packie88 Posted July 21, 2008 Author Share Posted July 21, 2008 okay cause im going to use my one with bolts with my ring gear. it should work. i havent torn open my one with studs. dont have to. got one that one with bolts. so ill be using that. ive got a carrier thats got 4.6's and an lsd if any one is intrested in that. lol Link to comment Share on other sites More sharing options...
