window wiper
Vertigo
On my 94 when I turn on the windshield wipers they apper to work fine however when you go to turn them off they wont shut off un till you turn the pathfinder. I also dont think the intermitant part is working correctly but when you put them on high it switches to high. Also the wash fluid pump doesnt seem to be working so I'm not sure if this problem is connected. Frist thing I though was that it must be the control arm so I swaped it out with on from another pathy at the wreakers and it didnt seem to solve my problem. Any ideas? Is there a seprate relay they wont release ?
-Vertigo
if you look at the electrical diagram for the 94 w/ intermittend wipers, there are a couple places that could cause the disruption you speak of. Take a look there first, throw a volt meter on a couple connectors and see if you have a short somewhere.
