racerdave Posted March 3, 2008 Share Posted March 3, 2008 91 XE-V6 Ignition Signal Missing In Primary Coil So to fix this I need a new distributor ? The distributor is what sends the signal to the coil correct? Link to comment Share on other sites More sharing options...
88pathoffroad Posted March 3, 2008 Share Posted March 3, 2008 Kind of...the ECU gets data from the distributor, then it sends a signal to the power transistor on the coil, which makes the coil fire. Could be wiring in between any of those parts or some of the parts themselves. Link to comment Share on other sites More sharing options...
racerdave Posted March 3, 2008 Author Share Posted March 3, 2008 what about the crank angle sensor in the distributor? Link to comment Share on other sites More sharing options...
GhostPath Posted March 3, 2008 Share Posted March 3, 2008 If it was the CAS, the truck wouldn't run. Link to comment Share on other sites More sharing options...
racerdave Posted March 3, 2008 Author Share Posted March 3, 2008 ok. isnt that the only electronic part in the distributor? Link to comment Share on other sites More sharing options...
Terrano1992 Posted March 3, 2008 Share Posted March 3, 2008 Sorry my poor English... "Ignition signal" is a feedback from primary ignition coil to ECCS module. If it is missed, it can be malfunction in: - wire harness and connectors (most likely, if your engine can start); - resistor or condenser in primary coil circuit; - power transistor module; - ignition coil itself. It isn't distributor or CAS malfunction. Link to comment Share on other sites More sharing options...
racerdave Posted March 4, 2008 Author Share Posted March 4, 2008 Sorry my poor English..."Ignition signal" is a feedback from primary ignition coil to ECCS module. If it is missed, it can be malfunction in: - wire harness and connectors (most likely, if your engine can start); - resistor or condenser in primary coil circuit; - power transistor module; - ignition coil itself. It isn't distributor or CAS malfunction. Yay, because a new distributor is like $$$ Thanks for the info, I am going out right now to check resistance and such. I will post the results tonight :-) thanks again. Link to comment Share on other sites More sharing options...
racerdave Posted March 4, 2008 Author Share Posted March 4, 2008 Well, I cant seem to find my OHM meeter, so I guess it will have to wait until tomorrow. :-\ Link to comment Share on other sites More sharing options...
Terrano1992 Posted March 4, 2008 Share Posted March 4, 2008 (edited) Well, I cant seem to find my OHM meeter, so I guess it will have to wait until tomorrow. Check all suspected connectors, wires and ground points thoroughly. I think, this picture may be helpful. "Ignition signal" circuit marked red. Edited March 4, 2008 by Terrano1992 Link to comment Share on other sites More sharing options...
racerdave Posted March 4, 2008 Author Share Posted March 4, 2008 Check all suspected connectors, wires and ground points thoroughly. I think, this picture may be helpful. "Ignition signal" circuit marked red. dude, u rock! This forum kicks @ss Thank you! Link to comment Share on other sites More sharing options...
