Code 21
racerdave
Sorry my poor English...
"Ignition signal" is a feedback from primary ignition coil to ECCS module. If it is missed, it can be malfunction in:
- wire harness and connectors (most likely, if your engine can start);
- resistor or condenser in primary coil circuit;
- power transistor module;
- ignition coil itself.
It isn't distributor or CAS malfunction.
Yay, because a new distributor is like $$$
Thanks for the info, I am going out right now to check resistance and such.
I will post the results tonight :-)
thanks again.
Well, I cant seem to find my OHM meeter, so I guess it will have to wait until tomorrow.
Check all suspected connectors, wires and ground points thoroughly. I think, this picture may be helpful. "Ignition signal" circuit marked red.
Edited by Terrano1992
dude, u rock!
This forum kicks @ss
Thank you!
