boothill2008 Posted February 26, 2008 Share Posted February 26, 2008 Help!!! I noticed my brake master cylinder has needed filling about every 2 months, I don't see any obvious leaks from the master cylinder, and no fluid is visible weeping onto the wheels, what's the best way to troubleshoot this leak?? Thanks, Boot Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted February 26, 2008 Share Posted February 26, 2008 maybe you are wearing your brake pads insanely fast... could be leaking into your brake booster.. Link to comment Share on other sites More sharing options...
GrimGreg Posted February 26, 2008 Share Posted February 26, 2008 Pedal feel change at all? Pull the screen in the MC and watch the fluid in there while someone else pumps the brakes, and then watch while they push and hold the brake. If you see any bubbles you have a leak between the booster and MC. If not start bleeding each wheel to see if you find any air bubbles, if you do, then trace that line. Link to comment Share on other sites More sharing options...
GhostPath Posted February 26, 2008 Share Posted February 26, 2008 Pay special attention to the rears if you have drums in the back. Wheel cylinders can leak into the drums for a surprisingly long amount of time before it becomes obvious. Link to comment Share on other sites More sharing options...
muskokapaddy Posted February 27, 2008 Share Posted February 27, 2008 Help!!! I noticed my brake master cylinder has needed filling about every 2 months, I don't see any obvious leaks from the master cylinder, and no fluid is visible weeping onto the wheels, what's the best way to troubleshoot this leak?? Thanks, Boot Link to comment Share on other sites More sharing options...
muskokapaddy Posted February 27, 2008 Share Posted February 27, 2008 Help!!! I noticed my brake master cylinder has needed filling about every 2 months, I don't see any obvious leaks from the master cylinder, and no fluid is visible weeping onto the wheels, what's the best way to troubleshoot this leak?? Thanks, Boot check your pass frame rail for rear anti lock block may be leaking from there Link to comment Share on other sites More sharing options...
muskokapaddy Posted February 27, 2008 Share Posted February 27, 2008 there is a anti lock block on the pass frame rail by rear door this may be the mysterious leak had this problem myself Link to comment Share on other sites More sharing options...
