4x4 shifter warm
Xmas
Your shifter will get warm a little, but if you feel a hot air comming up through your boot is most likely ripped. Pretty easy to check on the older models as there sre only two snappers holding the top boot to the floor on the drivers side.
Thanks U 2.
Since I been driving more often and longer distance I start to feel it.
Somedays it seems to get warmer then others. Like today, same route to work and it was just a little bit warm (4x4 rod / shifter metal part of the rod), it was no where as warn as it was yesterday. I think I am going to change the differential fluids. It prob needs to be replaced
Oh - the boot is for sure ripped
Edited by Xmas
