Changing fluids
csutke
So im going to need to be changing all the fluids in my rig and its prob never been done and it just turned over to 70k miles. I have looked at the FSM and think that i have a pretty good idea as to what needs to be done but i still have a few questions.
1: When draining the coolant is it really nessacary to drain the coolant from the block as well? and im kinda lost on the steps of doing this.
2: What fluids do you recommend for Tranny, T-Case, Front diff and Rear LSD diff?
3: Any tips or trick to know about?
4: How long should something like this take to change out Coolant, Tranny, Front/Rear Diff, T-case?
5: Does checkers or other parts store recycle used coolant etc...?
Thanks
1. i normally flush the engine with water a couple of times first so, no.
2. diffs the gear oil.. tranny.. what you got? t-c.. what's in it now? atf or gl?
3. definitely undo the fill holes on the diffs and t-c first before draining.
4. can you multitask? how good are you? how many pans do you have? lol 1h-2h?
5. most if not all auto part stores recycle oils.
CSU - CurleyMan and I have been using Redline and love it. I have it in the Trans, T-case, and both diffs.
There is a dealer near Drake and Taft. Go west on drake, past taft....pass a small neighborhood on your left, turn left at the Complete Automotive Repair.....you cant miss it....he has a bunch of RV stored right off the steet...... Tell him that you drive a nissan and that I told you to come in......sometimes he gives out a discount :)
