inqydesu Posted June 24, 2004 Share Posted June 24, 2004 My rear windshield wiper sprayer doesn't work. It is an 89 - hence the 2 door. I can tell the pump is working, but nothing comes out the rear. I would imagine the line has gotten crimped/clogged/torn etc. Any suggestions for clearing a clog or repairing? I looked in the Nissan shop manual (Factory, not Chilton's) and it didn't have the routing of the line. Any one know how the line is routed? This isn't a huge deal, but since I moved to Vegas I get a lot more dust and it would be nice to be able to clear the rear windshield. I appreciate any help Link to comment Share on other sites More sharing options...
88pathoffroad Posted June 24, 2004 Share Posted June 24, 2004 Take the inside plastic panels off and use a flashlight to find the hose inside the sheetmetal. It's most likely right under your nose...go look. Link to comment Share on other sites More sharing options...
sw Posted June 24, 2004 Share Posted June 24, 2004 ah dont bother with the plastic trim, most likely the end is blocked. just go to your rear hatch and pull out the plastic lines in the top of the door, they simply pull apart, pull the 'jets' off the back door and clean it out with hot water and compressed air. put it back in and reajust the possition of where is sprays the water on the window Link to comment Share on other sites More sharing options...
denisb Posted June 24, 2004 Share Posted June 24, 2004 If you want to know if your nozzle is cloged, disconnect the nozzle like sw said and hit your button. If fluid comes out clean your nozzle. If not start pulling the next panel where your hose is going to next. It's a great learning experience to see how your inside panels come off Link to comment Share on other sites More sharing options...
inqydesu Posted June 25, 2004 Author Share Posted June 25, 2004 i've allready pulled all the inside trim panels off allready (to wire for a/v and other gadgets - i didn't see the line - and was hoping to save a bit of time. now just to figure out how the dang nozzle comes off.... Link to comment Share on other sites More sharing options...
sw Posted June 25, 2004 Share Posted June 25, 2004 two small clips on the inside sorry not much help, i didnt figure out how get it out without damaging it * goes and gets slot screwdriver, leaver, leaver, snap..... doh, wheres my super glue..... * Link to comment Share on other sites More sharing options...
