Will a Warn Manual hub fit into this stock '03 Pathfinder rim?
pixel41
Does anyone know if this 2003 Pathfinder rim will work with a Warn Manual hub? I want to install the Warn hub and HOPEFULLY just use my original wheels. Anyone have this setup? (or know one way or another?).
Also, actually i guess i should ask if a BFG AT 31x10.50 will FIT on this rim as well. It's 16x7.
Thanks guys
Edited by pixel41
the hubs might work if the center bore is big enough but you will have to lose the center caps as for the tires you will have to go to a metric size with a 16" wheel the closest size to a 31x10.5 is 255/75 R16 that will put you at 31.1x10"
