pixel41 Posted February 4, 2008 Share Posted February 4, 2008 (edited) Does anyone know if this 2003 Pathfinder rim will work with a Warn Manual hub? I want to install the Warn hub and HOPEFULLY just use my original wheels. Anyone have this setup? (or know one way or another?). Also, actually i guess i should ask if a BFG AT 31x10.50 will FIT on this rim as well. It's 16x7. Thanks guys Edited February 4, 2008 by pixel41 Link to comment Share on other sites More sharing options...
csutke Posted February 4, 2008 Share Posted February 4, 2008 the hubs might work if the center bore is big enough but you will have to lose the center caps as for the tires you will have to go to a metric size with a 16" wheel the closest size to a 31x10.5 is 255/75 R16 that will put you at 31.1x10" Link to comment Share on other sites More sharing options...
nissandoms47 Posted February 5, 2008 Share Posted February 5, 2008 No they wont work with that wheel. My friend had the same wheels on his 03 and warn hubs wouldnt fit through the center hub. Link to comment Share on other sites More sharing options...
