bcuz Posted January 23, 2008 Share Posted January 23, 2008 I got a 95 pathy recently, It has some front end damage on the drivers side. I was just wondering if a Fender from a 91 nissan p/u would be the same? Link to comment Share on other sites More sharing options...
dagwoodzz Posted January 23, 2008 Share Posted January 23, 2008 I got a 95 pathy recently, It has some front end damage on the drivers side. I was just wondering if a Fender from a 91 nissan p/u would be the same? Yes, I sold my Hood and driver side fender from a '95 to guy with a hardbody. It was a '90 or '91 iirc. Link to comment Share on other sites More sharing options...
jj big shoe Posted January 23, 2008 Share Posted January 23, 2008 The "bulge" over the wheel is different between a 2wd and a 4wd, though. The 4wd sticks out more. Link to comment Share on other sites More sharing options...
dagwoodzz Posted January 23, 2008 Share Posted January 23, 2008 Didn't know that. thanks for the correction Link to comment Share on other sites More sharing options...
GrimGreg Posted January 23, 2008 Share Posted January 23, 2008 The "bulge" over the wheel is different between a 2wd and a 4wd, though. The 4wd sticks out more. Addition to that, all 2wd Pathfinders have the 4wd fenders. Only 2wd pickups got the "nerfed" little bulges. Link to comment Share on other sites More sharing options...
iluvmy95pathfinder Posted February 7, 2008 Share Posted February 7, 2008 HEY I AM REPLACING THE DRIVER'S SIDE FENDER on my 95. HAVE ANY of y'all done that before? I need help removing the cowl. do y'all know if te wiper blade arm just "pops" off after the bolt is removed? Link to comment Share on other sites More sharing options...
Simon Posted February 7, 2008 Share Posted February 7, 2008 (edited) Yes. However, corrosion sometimes seizes them on there pretty good. Some penetrating oil, and a couple of taps on the sleeve should break it loose. That is, of course, if you don't have a puller. Edited February 7, 2008 by Simon Link to comment Share on other sites More sharing options...
bcuz Posted February 10, 2008 Author Share Posted February 10, 2008 Well i picked up a fender for free but it turns out to be a 2wd hardbody :<. And yes the wiper blade arm just came right off for me. Link to comment Share on other sites More sharing options...
iluvmy95pathfinder Posted February 11, 2008 Share Posted February 11, 2008 I did it!! I put the new fender on!! I never did get the wiper blade arm off...and I tell you what its tough turning a wrench under the cowl...good thing I got small hands. Whats weird is the flare. My pathy's 4WD and the replacement fender is too but the flare on the new fender is shorter and won't accomodate the mud flap...so I guess I need to swap out the flares. and do any of y'all know how to find the matching paint? my PF is a '95 will that make it hard to match? I'll need a pinstripe too. oh and I tried a gear puller thing but it was too big. those little black plastic grill plates near the wiper blades got all messed up when my bros tried pulling the cowl off, can you get replacments for those? or am I gonna be using duck tape to patch 'em up? Link to comment Share on other sites More sharing options...
GrimGreg Posted February 11, 2008 Share Posted February 11, 2008 If you want to paint and stripe yourself on the cheap side, get some of the Duplicolor that matches and stick on stripes. For the cowel vents, yes you can get new pins, but dealer only IIRC. Link to comment Share on other sites More sharing options...
