basic tune up
The gas and temp guages are run by a small voltage regulator on the backside of your dash. The regulator's gone out on you if they're not working. A write-up on how to fix that is posted in the Garage section. Search for "voltage regulator" and find the thread.
There's also a write-up on how to check error codes on your ECU posted at the top of the Garage forum, read that if you want to check your ECU for error codes to see what's happening.
I'd say try changing the plugs, wires, cap and rotor and see if that helps. Lots of people report great success after changing out the simple stuff like that.
