ozzy Posted November 7, 2007 Share Posted November 7, 2007 (edited) i found the 31 BFG's i want for my r50 i also found the Cragar Soft 8's i want but i think the backspacing is 4.0? will that work? Edited November 8, 2007 by ozzy Link to comment Share on other sites More sharing options...
projekz Posted November 7, 2007 Share Posted November 7, 2007 It will work. Backspacing is the space between the edge of the rim and the hub Link to comment Share on other sites More sharing options...
jj big shoe Posted November 8, 2007 Share Posted November 8, 2007 Here ya go. Backspacing 101 Link to comment Share on other sites More sharing options...
ozzy Posted November 8, 2007 Author Share Posted November 8, 2007 Here ya go. Backspacing 101 sweet, thanks for the help. Link to comment Share on other sites More sharing options...
XPLORx4 Posted November 8, 2007 Share Posted November 8, 2007 That link incorrectly used the terms "backspacing" and "offset" interchangeably. Backspacing is not the same thing as offset, as that link may lead you to believe. Backspacing is the distance from the inner edge of the rim to the hub mounting surface. (They got that right.) Offset, however, is the distance between the centerline of the wheel and the hub mounting surface, and is usually measured in millimeters. Wheel Offset Explained Link to comment Share on other sites More sharing options...
ozzy Posted November 9, 2007 Author Share Posted November 9, 2007 That link incorrectly used the terms "backspacing" and "offset" interchangeably. Backspacing is not the same thing as offset, as that link may lead you to believe. Backspacing is the distance from the inner edge of the rim to the hub mounting surface. (They got that right.) Offset, however, is the distance between the centerline of the wheel and the hub mounting surface, and is usually measured in millimeters. Wheel Offset Explained ...i hope they'll work, hah -- i might just get BS 3.75 steelies. Link to comment Share on other sites More sharing options...
ozzy Posted November 10, 2007 Author Share Posted November 10, 2007 ...i hope they'll work, hah -- i might just get BS 3.75 steelies. no ones really clarified it for me yet... the cragar soft 8's backspacing 4.00 and im just wondering if they'll fit stock, because those are being sold for a very decent price on summitracing.com -- unless someone knows wheels that have 3.75 bs and are going for 40 bucks as well? Link to comment Share on other sites More sharing options...
csutke Posted November 10, 2007 Share Posted November 10, 2007 (edited) i have 4" bs and they fit fine after some trimming. i do have the 2" AC lift though but they would have fitted stock with some major trimming. As you can see the tires do stick out from the fender and also notice that i have fender flares, so thats up to you and how much you want you tires to stick out from the fender, also check with your local law enforcement as there as some places that laws telling you how far your tires can stick out Edited November 10, 2007 by csutke Link to comment Share on other sites More sharing options...
ozzy Posted November 10, 2007 Author Share Posted November 10, 2007 i have 4" bs and they fit fine after some trimming. i do have the 2" AC lift though but they would have fitted stock with some major trimming. As you can see the tires do stick out from the fender and also notice that i have fender flares, so thats up to you and how much you want you tires to stick out from the fender, also check with your local law enforcement as there as some places that laws telling you how far your tires can stick out nice, looks good man. hmm... i still don't know dude, i'd got 3.75 bs but i cant find the right wheel. Link to comment Share on other sites More sharing options...
